[gdal-dev] Re: Problem joining a shapefile and MDB
Brent Fraser bfraser at geoanalytic.com
Fri Nov 18 16:11:00 EST 2011
A response from the mapserver list:
http://forums.devarticles.com/microsoft-sql-server-5/data-source-name-not-found-and-no-default-driver-specified-8346.html
When you use a 64bits Windows, ODBC manager at Control Panel will only
create 64bits connection.
I had problems with that in the past and had to force 32bits
connections using 32bits ODBC manager at
C:\Windows\SysWOW64\odbcad32.exe
Best Regards,
Brent Fraser
On 11/18/2011 2:00 PM, boesiii wrote:
> Even,
> What is the correct procedure to upgrade a MS4W installation?  I downloaded
> release-1310-gdal-1-8-1-mapserver-6-0-1.zip and I copied OGRINFO.EXE to the
> current location.  After I did this OGRINFO still crashed.  Do I need to
> copy other files?
> Thanks,
> Ed
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-joining-a-shapefile-and-MDB-tp7009404p7009680.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
