[gdal-dev] Resquest for comments (RFC 36)
Frank Warmerdam
warmerdam at pobox.com
Mon Oct 3 22:04:07 EDT 2011
On Mon, Oct 3, 2011 at 6:14 PM, Daniel Morissette
<dmorissette at mapgears.com> wrote:
> I like the idea, especially since it can increase performance in some cases.
> However unless I'm mistaken the proposed patch seems to fall back on the
> regular test-open loop when the GDALOpenInternal() call with the explicit
> driver name failed, no matter why it failed. e.g. I specify the invalid
> "hfa:test.tif" open string, then I should get a NULL return value and not a
> handle to a TIFF file.
Daniel,
I believe that is because it is hard to know if HFA:test.tif was really
something other than a request for the HFA driver. It could actually
be a file named "HFA:test.tif" or it could be that another driver happens
to use the HFA: prefix to mean something. I believe this is an
effort to avoid failure in these cases.
> The patch would need to be reworked for this, but I think that if the
> GetDriverByName() call succeeds (i.e. the driver name prefix is recognized
> by GDAL) and the call to poDriver->pfnOpen() fails then we should return
> NULL to the application code (and not fall back on the test-open loop).
> OTOH, if the GetDriverByName() lookup failed, then we should fall back on
> the test-open loop.
> Also, if we implement this mechanism in GDAL, then we'd have to provide it
> in OGR as well to be consistent.
I'm not convinced that this is necessary. I have had a hope for
some time to provide a standard way of binding up open options,
including the driver name, for OGR as demonstrated by a
request like:
@driver=ingres,dbname=test
One objection I had previously to Ivan's proposal is that I'm
interested in pursuing this general purpose mechanism for
many open options in OGR and in GDAL. But since I haven't
gotten to it for so long there is no point in holding up Ivan's
fairly straight forward change. Nevertheless, I'm hesitant to
push his change to OGR unnecessarily.
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
