[gdal-dev] sandbox access for non-commiters
Etienne Tourigny etourigny.dev at gmail.com
Fri Oct 7 10:17:34 EDT 2011
On Thu, Oct 6, 2011 at 5:52 PM, Antonio Valentino
<antonio.valentino at tiscali.it> wrote:
> Hi Etienne,
> Il 06/10/2011 22:01, Etienne Tourigny ha scritto:
>> Thanks for the information.  It seems that using git-svn is more
>> suited for working locally, and then commiting back to the svn repos,
>> or as an easy way to stay in-sync with the main repos (like you do).
> IMHO the trick is using a separate branch for developing new features in
> order to be able to use git freely.
Is there a way to create a git repo from a subdirectory of the svn?
I'm not sure such a thing is possible, because the git stuff is at the
root of the source tree
I really just need the frmts/netcdf directory, which is the best
option (and which is possible)?
1) get a clone of just that directory using git svn ; create a branch;
push to a new git repos
2) get a clone of the full source tree using git svn ; create a branch
; push the subdirectory to a new git repos
regards,
Etienne
> When the job is done one should just rebase (locally) on the branch in
> sync with svn and use git-svn to push hanges back into svn.
> The weak point in the workflow is the initial cloning of the svn repo.
>> For now, I will stick to straight svn (or straight git) because I
>> don't know enough about git and don't want to break things!
>> thanks, Etienne
> Antonio Valentino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
