[gdal-dev] PostgreSQL problems
Eli Adam eadam at co.lincoln.or.us
Thu Oct 13 20:51:22 EDT 2011
David,
     It probably is a configuration or simple error, however, you've
not given much detail to let other people try to guess what it might
be.  Kyle asked for the output of your command.  Also, the exact
command (copied from terminal) may help too.  I looked at the OGR
PosrgreSQL/PostGIS format page and copied this:
PG:"dbname='databasename' host='addr' port='5432' user='x' password='y'"
Could you try
ogrinfo PG:"dbname='mydb' host='localhost' port='5432' user='x' password='y'"
from the host machine?
What do you get?
PostgreSQL requires very complex quoting if you have any CAPs, do you
have any caps in the db name, table, name, fieldname, etc?  With lack
of information, I'm making random guesses that may not be relevant.
I'm sure that if you provide detailed information, someone
knowledgeable will quickly help you (or at least that is what I often
observe on this list).
Bests, Eli
On Thu, Oct 13, 2011 at 5:10 PM, David J. Bakeman <dbakeman at comcast.net> wrote:
> Mateusz Łoskot wrote:
>> On 13 October 2011 23:47, David J. Bakeman<dbakeman at comcast.net>  wrote:
>>> I'm on Fedora core 14 with gdal 1.7.3.
>>> I setup postgre and created a spatial enabled database with a table that
>>> includes geometry.  I can connect using psql mydb.  However when I try
>>> ogrinfo -ro PG:dbname=mydb it fails saying no driver found.
>> ogrinfo --formats | grep -i post
> -> "PostgreSQL" (read/write)
> I really think it's some configuration thing but I don't know what it is?
>> and see if your GDAL/OGR installation has built-in PostgreSQL support.
>> Best regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
