[gdal-dev] Ogr2ogr datum shift
Stacy Supak sksupak at ncsu.edu
Thu Sep 15 01:11:54 EDT 2011
Hi community,
Is there a way to add a datum shift parameter to a reprojected shp in an ogr2ogr call?
I am using ogr2ogr to extract a shp from a postgis database and within the command I am reprojecting features from google Mercator to EPSG 4326. In the process of going from a spherical coordinate system to an elliptical one, the latitude of the  shp is shifted north by .18 degrees. I was informed by a knowledgable member of the listserve that cs2cs could solve this problem, but can this command work on vector data or just coordinates? If it is possible to use cs2cs on a shp, do I simply run the command immediately after the ogr2ogr command?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110914/7f72d2c7/attachment.html
