[gdal-dev] Warning 1: Multi-column primary key in 'raster_columns' detected but not supported.
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Apr 3 22:53:31 EDT 2012
Peter,
Perhaps you don't have permissions to write to the geometry_columns table.
Unfortunately the PG driver does not convey the error message from the
database.
On Tue, Apr 3, 2012 at 11:19 PM, Peter Tittmann <ptittmann at gmail.com> wrote:
>  Hi,
> Using PostGIS 2 and gdal 1.7.3
> Trying to run a simple ogr2ogr:
> ogr2ogr -skipfailures -f "PostgreSQL" PG:"dbname=afri" us9805_dni.shp
> returns:
> supported.
> ERROR 1: AddGeometryColumn failed for layer us9805_dni, layer creation has
> failed.
> Any suggestions would be welcome.
> Thanks!
> Peter Tittmann
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120404/1baca41f/attachment.html
