[gdal-dev] Slow writing into Spatialite with -skipfailures
Even Rouault even.rouault at mines-paris.org
Wed Apr 4 13:28:23 EDT 2012
Le mercredi 04 avril 2012 19:16:34, Rahkonen Jukka a écrit :
> Even Rouault wrote:
> >Selon Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>:
> >> Hi,
> >> I had to write a million polygon shapefile into Spatialite with
> >> -skipfailures and I noticed that it was very many times slower that
> >> without -skipfailures. Is
> >> there some logical reason for that or could it be due to a bug or
> >> something? Only thing that comes into my mind is that if the -gt
> >> parameter is taken into account or not.
> > This is expected. When you use -skipfailures, the -gt parameter is
> > ignored and virtually set to 1 so that transactions only take into
> > account one single feature at a time.
> Well, doing 1.1 million transactions for Spatialite db is too slow. Any
> suggestions about how to clean the shapefile fast and effectively
> beforehand? The shapefile is created by ogr2ogr, from Oracle table into
> shapefile. I have used -nlt multipolygon in both runs (Oracle ->
> shapefile, shape ->Spatialite).
What is the error reported when inserting features into the Spatialite DB that
makes the use of -skipfailures necessary ?
> -Jukka Rahkonen-_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
