[gdal-dev] Layer operations, a proposal
Ari Jolma ari.jolma at gmail.com
Tue Apr 17 17:42:51 EDT 2012
Folks,
I propose a set of new methods for OGR layers (see the PDF). I took the
basic ideas from page
http://courses.washington.edu/gis250/lessons/Model_Builder/ which seems
rather comprehensive. I wrote the pseudo code myself quickly (thus it
may not be optimal and may contain bugs - improvement suggestions are of
course welcome).
I was considering to write these in Perl (on top of the Perl bindings)
but probably they could also be in OGR core. Code-wise they would
probably go into ogrlayer.cpp.
If there is support/interest, I assume I should submit this as a RFC
(with a patch)?
Best regards,
Ari
Name: layer operations.pdf
Type: application/pdf
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120418/3af8de8a/layeroperations-0001.pdf
