[gdal-dev] Enabling DAP appears to disable several other formats
Thu Apr 19 21:40:02 EDT 2012
Charlie,
The typical reason would be that adding opendap adds stuff into the
libraries list that results in other "test links" failing.  It would
be helpful if you could file a bug and attach the config.log.
Best regards,
Frank
On Thu, Apr 19, 2012 at 6:20 PM, Charlie Sharpsteen
<chuck at sharpsteen.net> wrote:
> I'm trying to add support for OpenDAP to a build of GDAL on OS X. However,
> when I add `--with-dods-root` to my configure arguments,
> I inexplicably loose support for Epsilon, cURL, SpatiaLite and FreeXL.
> Full configure logs can be found here:
>   https://gist.github.com/2425147
> The diff between the configure output before and after adding DAP is:
> diff --git a/gdal_without_dap.log b/gdal_with_dap.log
> index 2eb06b3..405300f 100644
> --- a/gdal_without_dap.log
> +++ b/gdal_with_dap.log
> @@ -244,17 +244,22 @@ checking for Google libkml... yes
>  checking if Google libkml version is >= 1.3.0... no
>  using odbc library from /usr/local.
>  checking if Oracle support is enabled... no
> -checking Checking for DODS... disabled
> +checking Checking for DODS... libdap < 3.10
> +libdap >= 3.9
> +setting DODS root directory to /usr/local
>          found libcurl version 7.19.7
> -checking for curl_global_init in -lcurl... yes
> -checking for spatialite_init in -lspatialite... yes
> -enabled
> +checking for curl_global_init in -lcurl... no
> +checking for spatialite_init in -lspatialite... no
> +disabled
> +checking for sqlite3_open in -lsqlite3... yes
> +checking for SQLite3 library >= 3.0.0... yes
>  checking Checking for DWGdirect... disabled
>  configure: "IBM Informix DataBlade support disabled."
>  configure: checking whether we should include ESRI SDE support...
>          ESRI SDE support not requested.
>  checking for VFK support... yes
> -checking for eps_read_block_header in -lepsilon... yes
> +checking for eps_read_block_header in -lepsilon... no
> +libepsilon not found - EPSILON support disabled
>  checking for geos-config... /usr/local/bin/geos-config
>  checking for GEOS version >= 2.2.0... yes
>  checking for GEOSversion in -lgeos_c... yes
> @@ -263,7 +268,10 @@ checking for OpenCL support... no
>  checking for FreeXL support... checking freexl.h usability... yes
>  checking freexl.h presence... yes
>  checking for freexl.h... yes
> -checking for freexl_open in -lfreexl... yes
> +checking for freexl_open in -lfreexl... no
> +libfreexl not found - FreeXL support disabled
>  checking whether to enable PAM... yes
>  checking for poppler... yes
>  checking if Catalog::optContent exists... yes
> @@ -318,9 +326,9 @@ GDAL is now configured for i386-apple-darwin10.8.0
>    MrSID/MG4 Lidar support:   no
>    MSG support:               no
>    GRIB support:              yes
> -  EPSILON support:           yes
> +  EPSILON support:           no
>    WebP support:              no
> -  cURL support (wms/wcs/...):yes
> +  cURL support (wms/wcs/...):no
>    PostgreSQL support:        yes
>    MySQL support:             no
>    Ingres support:            no
> @@ -337,9 +345,9 @@ GDAL is now configured for i386-apple-darwin10.8.0
>    GEORASTER support:         no
>    SDE support:               no
>    Rasdaman support:          no
> -  DODS support:              no
> +  DODS support:              yes
>    SQLite support:            yes
> -  SpatiaLite support:        yes
> +  SpatiaLite support:        no
>    DWGdirect support          no
>    INFORMIX DataBlade support:no
>    GEOS support:              yes
> @@ -348,7 +356,7 @@ GDAL is now configured for i386-apple-darwin10.8.0
>    Podofo support:            no
>    OpenCL support:            no
>    Armadillo support:         no
> -  FreeXL support:            yes
> +  FreeXL support:            no
>    Mac OS X Framework :       no
> Any ideas why providing configure with the info to find one package is
> hosing four unrelated packages?
> Thanks!
> -Charlie
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
