[gdal-dev] Enabling DAP appears to disable several other formats
Charlie Sharpsteen chuck at sharpsteen.net
Thu Apr 19 21:48:06 EDT 2012
On Thu, Apr 19, 2012 at 6:40 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Charlie,
> The typical reason would be that adding opendap adds stuff into the
> libraries list that results in other "test links" failing.  It would
> be helpful if you could file a bug and attach the config.log.
> Best regards,
> Frank
I looked through the config.log a little closer, and in all four cases the
following argument was added to the compiler flags:
    -arch x86_64 i386 ppc
This is bad for two reasons:
  - I'm not trying to build a universal binary and all of my components are
x86_64 only.
  - `-arch x86_64 i386 ppc` isn't even a valid compiler flag. The proper
thing to pass would be `-arch x86_64 -arch i386 -arch ppc`, so the compiler
would error out even if I had the universal binaries to support a 3-way
build.
I've traced the offending flags to `dap-config` so it looks like this is an
OpenDAP bug now, not a GDAL bug.
Apologies for the noise.
-Charlie
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120419/73b4cced/attachment.html
