[gdal-dev] Compiling libCurl with GDAL v1.9
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Aug 13 05:26:33 PDT 2012
Hi Paul,
I compile libCurl with the MSVC compiler, and I follow the "MSVC from
command line" instructions at http://curl.haxx.se/docs/install.html
I set the ZLIB and OPENSSL paths as suggested as well.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 12-08-13 8:12 AM, Paul Meems wrote:
> Hi all,
> I'm trying (again) to compile GDAL with libCurl support.
> I'm on Windows using VS2008Pro.
> I'm using GDALv1.9.
> I went to this page http://trac.osgeo.org/gdal/wiki/LibCurl
> On this page a link is provided to a package.
> That link is no longer working.
> So I tried looking for the package myself.
> I've downloaded curl-7.27.0-ssl-sspi-zlib-static-bin-w32.zip from
> fossies.org <http://fossies.org> and curl-7.27.0-devel-mingw32.zip from
> haxx.se <http://haxx.se> both both don't have the needed lib files.
> So my question is:
> How to obtain the correct libCurl package?
