[gdal-dev] use of ogr2ogr with SAP Data Services
Paul Wheeler pwheeler at digitalglobe.com
Tue Aug 14 10:02:11 PDT 2012
Using ogr2ogr with data services, running batch file, from data services
job.
It will work on 3.2 not on 4.0, batch files run to completion from
command prompt on both servers, however, when bat file is ran for 4.0
fails to execute, 4.0 will run any other batch file we have.
Paul
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120814/848bd132/attachment.html>
