[gdal-dev] gdaltindex
Smith, Michael ERDC-RDE-CRREL-NH Michael.Smith at erdc.dren.mil
Tue Aug 21 14:29:40 PDT 2012
Mapserver does. I've used Oracle as a source for a tile index so sqlite
should work as well.
See
https://github.com/mapserver/mapserver/wiki/MapServer-TILEINDEXes-with-Data
base-RASTERS for using Oracle
And you could add SQLite to the Wiki as well (if it works).
Mike
On 8/21/12 5:24 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
>Le mardi 21 août 2012 23:09:19, Ian Walberg a écrit :
>> Hello folks,
>> Can gdaltindex create a sqlite db instead of a shapefile.
>Not directly, but you can use ogr2ogr to convert it to a sqlite db
>> This would be for use with mapserver and we are finding some references
>> to non shapefiles but cannot get it to work.
>I'm not sure that MapServer supports something else than shapefiles as
>valid
>format for tile index. You should confirm with the MapServer team.
>> Thanks
>> Ian
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
