[gdal-dev] gdaltindex
Ian Walberg ian.walberg at airborne.aero
Tue Aug 21 14:32:40 PDT 2012
Thanks for the details.
We have tried taking a working shp tileindex file and converting it using ogr2ogr and we were getting errors.
Let us look again.
Regards
Ian
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Smith, Michael ERDC-RDE-CRREL-NH
Sent: Tuesday, August 21, 2012 2:30 PM
To: Even Rouault; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdaltindex
Mapserver does. I've used Oracle as a source for a tile index so sqlite should work as well.
See
https://github.com/mapserver/mapserver/wiki/MapServer-TILEINDEXes-with-Data
base-RASTERS for using Oracle
And you could add SQLite to the Wiki as well (if it works).
Mike
On 8/21/12 5:24 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
>Le mardi 21 août 2012 23:09:19, Ian Walberg a écrit :
>> Hello folks,
>> Can gdaltindex create a sqlite db instead of a shapefile.
>Not directly, but you can use ogr2ogr to convert it to a sqlite db
>> This would be for use with mapserver and we are finding some
>> references to non shapefiles but cannot get it to work.
>I'm not sure that MapServer supports something else than shapefiles as
>valid format for tile index. You should confirm with the MapServer
>team.
>> Thanks
>> Ian
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
