[gdal-dev] image Compilation of Qgis 1.8 with gdal svn (Windows7_64bits)
Joaquim Luis jluis at ualg.pt
Wed Dec 12 06:53:44 PST 2012
Do you really need to rebuild qgis?
I think replacing the old gdal dll by the new one will be (almost)
enough. In practice things are a bit more complicated because of the
gdal.dll dependencies, but nothing that a good hunt with "Dependency
Walker" cannot solve (and still much easier than rebuild qgis).
Joaquim
> Hello,
> I need to use qgis 1.8 with the last gdal svn 1.10.0 on my Windows 7 64 bits
> station.I know that i'm obliged to compile in a 1st time gdal svn&  in a 2nd
> time qgis targetting the gdal svn version. Up to now, i succeed in compiling
> gdal svn thanks to "TortoiseSvn"&  Visual Studio. Now, i 'm trying to
> compile Qgis1.8 thanks to this following "help install_api" :
>   http://www.qgis.org/api/INSTALL.html#toc13
> I 'm following the 4th part of this webpage called "Building on windows". I
> have chosen to use Visual C++ Express edition rather than MinGW. Up to now,
> i installed :*Cmake/Flex/Bison/SVN/GIT/OSGeo4W. For information, i have not
> installed  the "Microsoft Windows Server® 2003 R2 Platform SDK" (Core
> SDK/Build environment(x86 32 bits).
> Then, thanks to OSGeo4W(advanced_installation), i installed
> :*expat/fcgi/gdal/grass/gsl-devel/iconv/pyqt4/qt4-devel/qwt5-devel-qt4/sip/spatialite/libspatialindex-devel/python-qscintilla.
> For information, i chosen "Gdal_dev 1.8-Pre6"  even if i want the last
> version of gdal dev called "1.10.0", unselectable via this OSGeo4W_setup.
> Then, i pasted the file unistd.h from "GnuWin32\include" toward VC\include
> directory of my Visual C++ installation.
> Now, i'm at the step 4.1.3 called 'Setting up the Visual Studio project with
> CMake'. I do not understand the instructions and how to create the batch
> file.
> 1/ Do you think the method that I opted is adapted to my goal (use qgis with
> the last version of gdal svn that i have already compiled) ? This method is
> really the easiest and most viable?
> 2/Could you give me details in order i succeed  in creating the batch file.
> 3/How to ensure that  the building take into account the gdal svn that i
> have already compiled?
> In advance, thank you to throw light for me.
> With kind regards.
> IMAGE
> View this message in context: http://osgeo-org.1560.n6.nabble.com/image-Compilation-of-Qgis-1-8-with-gdal-svn-Windows7-64bits-tp5022355.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
