[gdal-dev] Some tables from mdb not exported to PostGIS
Eli Adam eadam at co.lincoln.or.us
Sun Feb 12 19:35:55 EST 2012
Assuming that you are using ogr2ogr on the xp computer, you can fairly
easily setup ODBC connections for the non-spatial tables,
http://gdal.org/ogr/drv_odbc.html
Doing the same from linux is somewhat more difficult, the easiest path
I think to be http://gdal.org/ogr/drv_mdb.html
You can see some of my previous similar attempts,
http://lists.osgeo.org/pipermail/gdal-dev/2011-November/030833.html
And this general topic seems to be ongoing so which version you are
using may be relevant depending on specifics,
http://trac.osgeo.org/gdal/changeset/23931
Bests, Eli
On Fri, Jan 27, 2012 at 6:50 PM, jjap <sabjap at gmail.com> wrote:
> Greetings,
> ogr2ogr has allowed me to successfully convert an ESRI personnal geodatabase
> from a Windows XP computer to an Ubuntu server 11.04 running PostGIS 1.5
> with proper encoding . The tables containing the blob/shapefiles all made it
> but not the others. Am I right to presume I'll have to migrate those other
> tables by hand and rebuild references?
> Am I missing some options which would have allowed me to do it in one fell
> swoop? Any hints appreciated.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Some-tables-from-mdb-not-exported-to-PostGIS-tp4344999p4344999.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
