[gdal-dev] Re: ogr2ogr GML creation encoding issue
Hermann Peifer peifer at gmx.eu
Sat Feb 25 04:19:37 EST 2012
On 24/02/2012 20:05, Even Rouault wrote:
> CC'ing the list in case someone has a better idea. I don't. Should work...
>>> Selon Travis Kirstine<traviskirstine at gmail.com>:
>>>> My Command
>>>> ogr2ogr -f GML -t_srs EPSG:4326 -s_srs EPSG:900913 -nln administrative
>>>> planet_osm_polygon_boundary_administrative.gml PG:'dbname=osmdb
>>>> user=osm' -sql "SELECT admin_level, name, way FROM planet_osm_polygon
>>>> WHERE boundary = 'administrative')"
Are you using ogr2ogr frim trunk?
Hermann
