[gdal-dev] Re: ogr2ogr GML creation encoding issue
Travis Kirstine traviskirstine at gmail.com
Tue Feb 28 08:12:20 EST 2012
It turns out that the issue was not related to ogr2ogr at all, the
translation worked fine.  The problem was two issues, first I was
using putty to access my server to run ogr, you need to have the
character set to be UTF-8 and have a font that supports the
characters.  The second issue was that QGIS seems to have a issue with
the GML encoding (works with PostGIS).
Thanks for the help
On 25 February 2012 04:19, Hermann Peifer <peifer at gmx.eu> wrote:
> On 24/02/2012 20:05, Even Rouault wrote:
>> CC'ing the list in case someone has a better idea. I don't. Should work...
>>>> Selon Travis Kirstine<traviskirstine at gmail.com>:
>>>>> My Command
>>>>> ogr2ogr -f GML -t_srs EPSG:4326 -s_srs EPSG:900913 -nln administrative
>>>>> planet_osm_polygon_boundary_administrative.gml PG:'dbname=osmdb
>>>>> user=osm' -sql "SELECT admin_level, name, way FROM planet_osm_polygon
>>>>> WHERE boundary = 'administrative')"
> Are you using ogr2ogr frim trunk?
> Hermann
