[gdal-dev] Compilation problem on Ubuntu
Simon R. Proud srp at geo.ku.dk
Sat Feb 25 09:11:42 EST 2012
Hello all,
I'm trying to compile GDAL 1.9.0 on Ubuntu 11.04, but am not having any luck.
I configure with:
./configure --with-hdf4 --with-hdf5 --with-grib --with-msg --with-python
And that works with no problems (I have the MSG wavelet transform code, by the way, so that's not the issue).
But, when I make I get this fatal error part-way through the compilation:
hdf4imagedataset.cpp: In member function 'void HDF4ImageDataset::GetSwatAttrs(int32)':
hdf4imagedataset.cpp:1723:41: error: 'SWsdid' was not declared in this scope
hdf4imagedataset.cpp: In member function 'void HDF4ImageDataset::GetGridAttrs(int32)':
hdf4imagedataset.cpp:1833:41: error: 'GDsdid' was not declared in this scope
hdf4imagedataset.cpp: In member function 'int HDF4ImageDataset::ProcessSwathGeolocation(int32, char**)':
hdf4imagedataset.cpp:2218:48: warning: deprecated conversion from string constant to 'char*'
hdf4imagedataset.cpp:2240:51: warning: deprecated conversion from string constant to 'char*'
hdf4imagedataset.cpp:2252:51: warning: deprecated conversion from string constant to 'char*'
make[2]: *** [../o/hdf4imagedataset.lo] Error 1
make[2]: Leaving directory `/GDAL/frmts/hdf4'
make[1]: *** [hdf4-install-obj] Error 2
make[1]: Leaving directory `/GDAL/frmts'
make: *** [frmts-target] Error 2
I have the following HDF5 libraries installed:
hdf4-tools (v4.2r4-11ubuntu1)
libhdf4-0 (v4.2r4-11ubuntu1)
libhdf4-alt-dev (v4.2r4-11ubuntu1)
libhdf-4-0-alt (v4.2r4-11ubuntu1)
libhdfeos0 (v2.16v1.00.dfsg.2-4)
libhdfeos-dev (v2.16v1.00.dfsg.2-4)
I've tried various combinations libraries (including the -alt and normal versions) and nothing seems to change the result, always the same error. Compilation completes successfully if I configure --without-hdf4. Unfortunately I need the MSG capability for GDAL (and would like fillnodata.py also) so cannot just use the Ubuntu GDAL package.
So, any idea what the problem might be?
Thanks,
Simon.
Dr Simon Proud
Post-doc, Satellite Remote Sensing
University of Copenhagen
Tel: +45 35 32 25 84
