[gdal-dev] Motion: Promote GDAL 1.9.0RC1 as GDAL 1.9.0 Final
Etienne Tourigny etourigny.dev at gmail.com
Tue Jan 3 09:04:31 EST 2012
William,
Can you comment on the status of support for netcdf4 + hdf5 in mac osx
? Has that been tested, or is it possible to include them in your
builds?
There have been a number of improvements to the netcdf driver for
1.9.0 (including support for netcdf-4), it would be nice to have that
included in your builds.  If you need help I can try to assist, but I
don't have a mac nor experience with osx.
thanks,
Etienne
On Mon, Jan 2, 2012 at 10:20 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> One configuration problem so far on OS X:
> - with-freexl - doesn't test for freexl with libiconv (I have freexl compiled as static library, so it doesn't automatically link libiconv).  I just added $LIBICONV to both the freexl tests to get this to work, but another test for whether freexl needs iconv is really needed.
> And one compile error:
> webpdataset.cpp:536: error: invalid conversion from 'int' to 'WebPEncCSP'
> I changed the offending line to:
>    sPicture.colorspace = WEBP_YUV420;
> and it compiles.
> If these can be fixed for 1.9.0 release that would be great, otherwise I'll add bug reports.
> On Dec 31, 2011, at 7:38 PM, Frank Warmerdam wrote:
>> Motion: To promote the GDAL/OGR 1.9.0RC1 release candidate as
>>            the final GDAL/OGR 1.9.0 release.
>> +1 Frank
>> I have done a wee bit of testing and the release candidate seems
>> solid.  Other PSC members are encouraged to test and vote.
>> Feedback from other users is also welcome.
>> Voting will remain open until at least the end of day on
>> Tuesday.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Software Developer
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
> - the wisdom of Tarzan
