[gdal-dev] GDAL 1.7.3 java bindings on Centos 5 (64 bit)
Nikolaos Hatzopoulos nhatzop at gmail.com
Mon Jan 23 13:12:35 EST 2012
http://elgis.argeo.org/
this repo has java bindings if that helps
--Nikos Hatzopoulos
On Mon, Jan 23, 2012 at 9:12 AM, Daniele Romagnoli <
daniele.romagnoli at geo-solutions.it> wrote:
> Hi list,
> Does anyone have any experience about the reported topic?
> I have downloaded GDAL 1.7.3 on my Centos 5.7 (64) machine and built it
> (with only base drivers and with threads support).
> Utilities are working fine (gdalinfo, gdal_translate, ...)
> Then, I have installed SWIG 1.3.36 (I know, it's quite old but testing
> 1.3.4X or 2.x in the past, I got several JVM crashes or other types of
> issues) and I have created java bindings for it.
> Once I have configured LD_LIBRARY_PATH to use all SOs it needs, I have
> started running some ImageIO-Ext tests with maven and JVM is crashing.
> In case someone don't know it, ImageIO-Ext mainly allows to bridge Java's
> ImageIO (ImageReaders/writers/SPI) to GDAL format drivers.
> On several Ubuntu (8, 9, 10, 11) I never had similar problems. We
> regularly use ImageIO-Ext 1.1.2 built on top of GDAL 1.7.3 on projects like
> GeoTools, GeoServer, Udig, ... Therefore I guess it's not a problem on the
> ImageIO-Ext caller side. I think it could be related to the SWIG-JNI
> counterpart which isn't working properly or something odd with the memory
> usage.
> Does anyone have any feedback on this? (supported/never tested/won't
> work/need some CXX flags/... anything)
> I'm pasting the hs_err_pid Log in case you find anything interesting.
> [1]: http://pastebin.com/WQkfnutJ
> Thanks in advance and best regards,
> Daniele
> ERROR: native gdal on centos 64 bit
>  T E S T S
> Running it.geosolutions.imageio.plugins.arcgrid.ArcGridReadTest
> Jan 23, 2012 11:42:45 AM it.geosolutions.imageio.gdalframework.GDALUtilities
> loadGDAL
> INFO: GDAL Native Library loaded (version: 1.7.3)
> # A fatal error has been detected by the Java Runtime Environment:
> #  SIGSEGV (0xb) at pc=0x00002b15a3ba7037, pid=9169, tid=1106860352
> # JRE version: 6.0_29-b11
> # Java VM: Java HotSpot(TM) 64-Bit Server VM (20.4-b02 mixed mode
> linux-amd64 compressed oops)
> # Problematic frame:
> # V  [libjvm.so+0x4e1037]  java_lang_String::utf8_length(oopDesc*)+0x67
> # An error report file with more information is saved as:
> # /root/tests/imageio1.1.2/plugin/gdal/gdalarcgrid/hs_err_pid9169.log
> # If you would like to submit a bug report, please visit:
> #   http://java.sun.com/webapps/bugreport/crash.jsp
> /bin/sh: line 1:  9169 Aborted
> /usr/lib/jvm/jdk1.6.0_29/jre/bin/java -Xmx512M -enableassertions
> -Dtest.extensive=false -Dtest.interactive=false -jar /tmp/
> surefirebooter8850919397384240961.jar /tmp/surefire7943635768826345743tmp
> /tmp/surefire4074398420042204599tmp
> Ing. Daniele Romagnoli
> GeoSolutions S.A.S.
> Software Engineer
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:      +39 0584 962313
> http://www.geo-solutions.it
> http://geo-solutions.blogspot.com/
> http://www.youtube.com/user/GeoSolutionsIT
> http://it.linkedin.com/in/danieleromagnoli
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120123/07033f74/attachment.html
