[gdal-dev] Rasterlite and external overviews
    Even Rouault
    even.rouault at mines-paris.org
    Mon Jul  9 13:04:49 PDT 2012
> While trying external overviews I found two troubles. First one is that
> it isimpossible to build external overviews if there has been internal
> overviews in the table. Removing them with "gdaladdo -clean" does not
> help, the message is still:
> ERROR 6: Cannot add external overviews to a dataset with internal overviews
> Overview building failed.
I don't reproduce that. Did you check with gdalinfo that the internal overview
was properly cleaned ?
> Another problem is not big. Gdaladdo just gives a faulty error message
> first but it still creates external overviews. This is what gets printed
> on the screen:
> gdaladdo -ro RASTERLITE:addotest3.sqlite,table=t8000 2 4 8
> ERROR 4: `addotest3.sqlite_t8000' does not exist in the file system,
> and is not recognised as a supported dataset name.
ok, I've just fixed that.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> It would be really good to have at least average method also for
> internal overviews.
Thinking about it again, this might be doable with modest code addition in the
driver. Please file a ticket about that.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
