[gdal-dev] Convert to temperature in degrees C in MODIS Ocean Color?
Etienne Tourigny etourigny.dev at gmail.com
Thu Jul 19 09:00:50 PDT 2012
I mean it requires the gdal python bindings and python installed.
You don't need python skills - it's a command-line program. Although
you may need to understand the numpy syntax if you have a complex
formula.
In your case it would be something like
gdal_calc.py -A input1.tif --outfile=result.tif --calc="0.000717185 *
A -2 " --type Float32
Etienne
On Thu, Jul 19, 2012 at 11:13 AM, sigologo <dlopezaspe at gmail.com> wrote:
> Thanks Etienne
>   But python is not my best skill in this session!!!!!!!!!!!!
> I will try!
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Convert-to-temperature-in-degrees-C-in-MODIS-Ocean-Color-tp4989237p4989377.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
