[gdal-dev] Convert to temperature in degrees C in MODIS Ocean Color?
Joaquim Luis jluis at ualg.pt
Thu Jul 19 11:01:28 PDT 2012
Unfortunately the GMT5 CookBook is no longer in html so I have to refer
you the section 4.21 - "Options for grids and images read via GDAL" - of
http://www.soest.hawaii.edu/gmt5/gmt/pdf/GMT_Docs.pdf
where you can see this example
"... Be warned, however, that things are not yet completed because while
the data are scaled according to the
equation printed above (“Scaling Equation=(Slope*l3m_data) + Intercept =
Parameter value”), this scaling
is not applied by GDAL on reading so it cannot be done automatically by
GMT. One solution is to do the
reading and scaling via grdmath first, i.e.,"
grdmath
A20030012003365.L3m_YR_NSST_9=gd?HDF4_SDS:UNKNOWN:"A20030012003365.L3m_YR_NSST_9:0"
0.000717185 MUL -2 ADD = sst.nc
Joaquim
> Thanks Etienne
>    But python is not my best skill in this session!!!!!!!!!!!!
> I will try!
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Convert-to-temperature-in-degrees-C-in-MODIS-Ocean-Color-tp4989237p4989377.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
