[gdal-dev] OSM Driver and World Planet file (pbf format)
Even Rouault even.rouault at mines-paris.org
Tue Jul 24 15:08:24 PDT 2012
Le lundi 23 juillet 2012 19:25:22, Smith, Michael ERDC-CRREL-NH a écrit :
> Even,
> [osmusr at bigserver-proc osm]$ ogr2ogr -progress -f oci
> oci:user/pass at tns:tmp planet-latest.osm.pbf -lco dim=2 -lco srid=4326 -lco
> geometry_name=geometry -lco launder=yes --debug on  2>osm_debug.log
> 0...10...20...30...40...50...60Š70
> From the debug output
Michael,
The debug output would suggest that there was no more data to process, which
is strange. I've tested a bit with a planet file dating back to a few weeks,
with a modified OSM driver that does basically no processing except the
parsing, and it managed to parse until the end of file. So in your situation,
I'd assume that there was a parsing error, but I'm not 100% positive (might be
something wrong in the "interleaved reading" mode ?)
I've commited in r24707 a change that is mainly a custom indexation mechanism
for nodes (can be disabled with OSM_USE_CUSTOM_INDEXING=NO) to improve
performances (Improve them about by a factor of 2 on a 1 GB PBF on my PC)
Along with that change, I've added some facility for extra error outputs. If a
parsing error occured, an error message will be printed. And, before
recompiling, you can edit ogr/ogrsf_frmts/osm/gpb.h and uncomment (by removing
the // at the beginning of //#define DEBUG_GPB_ERRORS) line 40. This should
report a more precise error if there's something wrong during the GPB parsing.
You might also retry with --debug OSM and, at the end of the processing,
you'll see a trace "Number of bytes read in file : XXXXXXXXXXX" : you can check
that the value is the same as the size of the PBF file.
Even
