[gdal-dev] Reading NetCDF using VB.NET
Etienne Tourigny etourigny.dev at gmail.com
Sat Jun 16 12:25:11 PDT 2012
Read my last email more attentively, you will see links the SDK built
by Tamas Szekeres, which supposedly work with csharp
On Sat, Jun 16, 2012 at 4:03 PM, Siebe Bosch <siebe at hydroconsult.nl> wrote:
> Thanks Etienne,
> You're probably right that I will need the latest GDAL in stead of the one
> in FWTools.
> Currently however I'm struggling with NMAKE to build the CSHARP-libraries.
> It gives me all sorts of error messages.
> Anyone up for some guidance on NMAKE via screen sharing in Skype (username
> Crusoe73) ?
> Or perhaps even better: does anyone already have a set of built DLL's that I
> can use straight away in Visual Studio 2008?
> By the way: here's what I'll need to do in total:
> 1. Receive co-ordinates for a rectangle from Google Maps (PHP)
> 2. Convert them to +proj=stere +x_0=0 +y_0=0 +lat_0=90 +lon_0=0 +lat_ts=60
> +a=6378.388 +b=6356.906
> 3. Extract data for the rectangle from a series of NetCDF files
> 4. Convert the results to EPSG 28992 projection
> 5. Export the converted results to a new series of NetCDF files (of other
> formats)
> Regards,
> Siebe
