[gdal-dev] zonal statistics with gdal
anssi anssisamuli at gmail.com
Wed Jun 20 06:41:04 PDT 2012
No problem at all,
you had a good point.
Anyone here who knows these issues thoroughly and could provide some
recommendations?
Cheers,
Anssi
On Wed, Jun 20, 2012 at 3:20 PM, Joaquim Luis <jluis at ualg.pt> wrote:
> Anssi,
> OK, may I overreact a bit. It's just that I don't like GPL much, specially
> when it used on codes that rely on non GPLed codes. But this thing of
> licensing issue is delicate (and boring), so you'll excuse me if I don't
> give you one opinion on what you should. The most I can say is that when I
> got a clearer grasp of GPL, I change the license of my code to LGPL.
> On a second read I see that you also depend on the gsl library, so perhaps
> you have to make it GPL. I don't know.
> Joaquim
>> Dear Joaquim,
>> thanks for pointing that out.
>> There´s absolutely no intention to abuse any of the great work of the
>> gdal/ogr developers. Rather the opposite.
>> The license is being discussed as we speak and we're considering
>> various options. What would you suggest? Should it be MIT or would ,
>> for example, Modified BSD License do?
>> Best,
>> Anssi
>> On Wed, Jun 20, 2012 at 2:49 PM, Joaquim Luis<jluis at ualg.pt>  wrote:
>>> One other thing called my attention. If, as we can read on the wiki page
>>> of
>>> OFGT
>>> "... Most of the stand-alone programs use GDAL libraries and many of the
>>> scripts rely heavily on GDAL command-line utilities."
>>> than why the OFGT's licence is GPL?
>>> I know MIT's license allows it, but it clearly looks an abuse to me.
>>> Joaquim
>>>> Distributing software via dropbox is a rather unusual practice, you
>>>> might consider hosting it elsewhere...
>>>> Etienne
>>>> On Wed, Jun 20, 2012 at 6:53 AM, chenliang wang<hi181904665 at msn.com>
>>>>  wrote:
>>>>> Hi, Anssi
>>>>> Cool ! Open Foris Geospatial Toolkit is a great geospatial library .
>>>>> Unfortunately, I can't download it from dropbox site because ofInternet
>>>>> censorship  of China. Can u upload it to other site or send it for me?
>>>>> Thanks a lot. I are a Linux and MINGW user .
>>>>> Chen-Liang Wang
>>>>> 于 2012-6-20 17:26, anssi 写道:
>>>>>> If you first rasterize your shapefile to the extent of your raster,
>>>>>> you can compute some basic stats and/or full histogram for your
>>>>>> polygons using Open Foris Geospatial Toolkit :
>>>>>> http://km.fao.org/OFwiki/index.php/Open_Foris_Toolkit
>>>>>> Installation instructions are under the "How to get it?" link.
>>>>>> Hope you're a Linux user :)
>>>>>> Best,
>>>>>> Anssi
>>>>>> On Wed, Jun 20, 2012 at 6:59 AM, Petteri Packalen
>>>>>> <packalen at cs.joensuu.fi>    wrote:
>>>>>>> Derek,
>>>>>>> Look at the http://starspan.projects.atlas.ca.gov project.
>>>>>>> Petteri
>>>>>>> On Tue, 19 Jun 2012, jdmorgan wrote:
>>>>>>>> Hello,
>>>>>>>> Is there a way to do something along the lines of zonal statistics
>>>>>>>> with
>>>>>>>> gdal.Basically, I have a county shape file and a classified raster
>>>>>>>> dataset.I
>>>>>>>> would like to count the number of raster pixels/county (FIPS).Is
>>>>>>>> this
>>>>>>>> possible with GDAL/OGR?If so can someone point me in the right
>>>>>>>> direction?
>>>>>>>>  If so, awesome as I plan to do some automation with python.
>>>>>>>> Thanks,
>>>>>>>> Derek
>>>>>>> _______________________________________________
>>>>>>> gdal-dev mailing list
>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
