[gdal-dev] strange behaviour with gdalwarp and LZW compression
Stefano Iacovella stefano.iacovella at gmail.com
Tue Mar 6 18:19:08 EST 2012
Hello all
I'm using gdal utilities to georeference some tiff files.
I'm inserting the gcp using:
 gdal_translate -gcp ....  original.tif original_gcp.tif
Then I use gdalwarp to gereference the images:
 gdalwarp -t_srs EPSG:32633 original_gcp.tif original_warp.tif
The resulting Geotiff is correctly georeferenced and the size is
approximately the same of the original
The problem arise if I insert the options -co COMPRESS=LZW at the
warping. The process end successfully but the resulting geotiff is 6
times the size of the original one!
I've tried to use:
gdal_translate -of GTIFF -co COMPRESS=LZW original_warp.tif
original_warp_lzw.tif
and it produces a geotiff smaller than the original.
Am I doing something incorrect?
thank you in advance
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
