[gdal-dev] Re: strange behaviour with gdalwarp and LZW compression
Stefano Iacovella stefano.iacovella at gmail.com
Tue Mar 6 18:20:30 EST 2012
Sorry
I forgot to say I'm using GDAL 1.9.0 compiled on ubuntu 10.04
2012/3/7 Stefano Iacovella <stefano.iacovella at gmail.com>:
> Hello all
> I'm using gdal utilities to georeference some tiff files.
> I'm inserting the gcp using:
>  gdal_translate -gcp ....  original.tif original_gcp.tif
> Then I use gdalwarp to gereference the images:
>  gdalwarp -t_srs EPSG:32633 original_gcp.tif original_warp.tif
> The resulting Geotiff is correctly georeferenced and the size is
> approximately the same of the original
> The problem arise if I insert the options -co COMPRESS=LZW at the
> warping. The process end successfully but the resulting geotiff is 6
> times the size of the original one!
> I've tried to use:
> gdal_translate -of GTIFF -co COMPRESS=LZW original_warp.tif
> original_warp_lzw.tif
> and it produces a geotiff smaller than the original.
> Am I doing something incorrect?
> thank you in advance
> Stefano
> 41.95581N 12.52854E
> http://www.linkedin.com/in/stefanoiacovella
> http://twitter.com/#!/Iacovellas
