[gdal-dev] shifting (or snapping) one raster to another
Derek Morgan jdmorgan at unca.edu
Fri Mar 23 10:56:00 EDT 2012
Thanks Doug, this is great feedback.  It is folks like you, and the others
who responded, that making working w/ open sources tools a pretty awesome
alternative.
Cheers,
Derek
On Fri, Mar 23, 2012 at 7:50 AM, <Doug_Newcomb at fws.gov> wrote:
> Derek,
>         You can do this in GRASS ( using gdal in the background)  by doing
> the following:
> 1) create a workspace in the same projection as your existing raster  (
> when you first start GRASS it will ask you to set up a workspace with
> projection information)
> 2)  import the existing raster layer into GRASS, ( r.in.gdal,
> http://grass.fbk.eu/​grass64/manuals/html64_user/r.​in.gdal.html<http://grass.fbk.eu/grass64/manuals/html64_user/r.in.gdal.html>
> 3)set the region to match the imported raster layer in extent and
> resolution (g.region, http://grass.fbk.eu/grass64/​manuals/html64_user/g.region.​html)
> <http://grass.fbk.eu/grass64/manuals/html64_user/g.region.html>
> 4) import the county vector layer (v.in.ogr, http://grass.fbk.eu/grass64/​manuals/html64_user/v.in.ogr.​html
> ) <http://grass.fbk.eu/grass64/manuals/html64_user/v.in.ogr.html>
> 5) convert the vector layer to a raster layer(v.to.rast, http://grass.fbk.eu/grass64/​manuals/html64_user/v.to.rast.​html)
> <http://grass.fbk.eu/grass64/manuals/html64_user/v.to.rast.html>
> When you create the new raster it will use the existing alignment and
> resolution of the region ( based off of the existing raster)  in the
> placement of the cells.  Even though I reference the tabular commands in
> the above process, it can be easily done through both GRASS gui's
> Doug
> Doug Newcomb
> USFWS
> Raleigh, NC
> 919-856-4520 ext. 14 doug_newcomb at fws.gov
> The opinions I express are my own and are not representative of the
> official policy of the U.S.Fish and Wildlife Service or Dept. of the
> Interior.   Life is too short for undocumented, proprietary data formats.
>  *Derek Morgan <jdmorgan at unca.edu>*
> Sent by: gdal-dev-bounces at lists.osgeo.​org<gdal-dev-bounces at lists.osgeo.org>
> 03/22/2012 10:12 PM
>   To
> gdal-dev at lists.osgeo.org
> cc
>   Subject
> Hello,
> I am in a jam with ArcGIS, and am hoping there is a easier way to do
> this with GDAL.  Here is the situation:  I am converting a vector
> dataset of county polygons to raster at a pixel resolution of 231 m.
> However, I want this to line up with a different raster dataset I have
> at a much larger extent, but also the same resolution 231 m. As you
> probably guessed the two datasets are slightly askew as they have
> different extents.  I would like to align the newly created county
> raster with the larger raster data set by shifting (or snapping) it to
> the closest pixels.  Hopefully, this makes enough sense for someone to
> let me know if this can be done in GDAL.
> Thanks ahead of time,
> Derek
> ______________________________​_________________
> gdal-dev mailing list
> http://lists.osgeo.org/​mailman/listinfo/gdal-dev
>  <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120323/2c189697/attachment.html
