[gdal-dev] vsicurl
Kyle Shannon kyle at pobox.com
Fri Mar 23 17:03:15 EDT 2012
Etienne,
I saw that under the vsizip section, but it wasn't clear to me if the same
constraints were on the vsicurl handler.
kss
On Fri, Mar 23, 2012 at 14:56, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> Kyle,
> the driver(s) probably need to support "large file API"
> From http://trac.osgeo.org/gdal/wiki/UserDocs/ReadInZip
> The fact that this new capability is implemented as virtual file
> systems imply that it will only work for GDAL drivers supporting the
> "large file API". A non-exhaustive list of such drivers is :
> The full list can be obtained by looking at the driver marked with 'v'
> when running 'gdalinfo --formats'
> for example, netcdf and hdf do not support /vsigzip (and probably not
> /vsicurl)
> Etienne
> On Fri, Mar 23, 2012 at 5:31 PM, Kyle Shannon <kyle at pobox.com> wrote:
> > What are the requirements for using the vsicurl handler for accessing
> files?
> > Do drivers have to implement anything special do have curl support?
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120323/ed2f57b8/attachment.html
