[gdal-dev] Re: gdal_translate waits at the end of operation
kaarigar kaarigar at gmail.com
Wed May 9 19:34:13 EDT 2012
Here's the command line:
gdal_translate -ot Float32 -of XYZ -co "COLUMN_SEPARATOR=," n40w124.tif
n40w124.xyz
Kyle Shannon-3 wrote
> Sounds like your doing something wrong, it shouldn't hang.  Can you share
> your command line args or a snippet of your batch file?
> kss
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4964307.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
