[gdal-dev] GeoPDF Writing support using Create()?
    Even Rouault
    even.rouault at mines-paris.org
    Wed Nov 21 04:11:44 PST 2012
Selon Robert Zermeno <refriguy68 at yahoo.com>:
> GDAL Community (Especially Even Rouault),
> It has been around 1 1/2 years the last time I had used GDAL and noticed GDAL
> now has capabilities of generating Geospatial PDF files from existing
> GDALDataset objects.  How far in the future do you see GDAL having
> capabilities of using Create() to generate your own Geospaital PDF?
> I would like to have the freedom of providing GDAL all the required, and
> optional, information needed to generate a Geospatial PDF file from a given
> image buffer my application possesses.  I am not sure if any other GDAL
> community members concur with my desire.
> What would be the effort level to supply Create() for Geospatial PDF files?
Implementing Create(), with the capability of random writing (for example like
being needed by gdalwarp or nearblack), is not doable due to the nature of PDF.
But as CreateCopy() is already implemented, you can for example create a
in-memory raster (see the MEM driver) and CreateCopy() it into a geospatial PDF.
> Robert
