[gdal-dev] GDAL/OGR C# wrapper and UTF8
Wed Apr 3 12:23:20 PDT 2013
Guys,
Certainly the intention of RFC 23:
  http://trac.osgeo.org/gdal/wiki/rfc23_ogr_unicode
Was that we consider OGR string fields to be utf8 and I believe that should
be the default assumption.
Best regards,
Frank
On Wed, Apr 3, 2013 at 12:17 PM, rburhum <ragi at burhum.com> wrote:
> Hello Tamas and Dennis,
> This is my personal opinion and there may tons of people that disagree, but
> I think it is more sane to always assume UTF8 encoding. There is
> functionality among the various drivers to accept/return strings in
> different encodings (through the CPL_Recode mechanism) but they all do it
> with different parameters (e.g. "PGCLIENTENCODING" in PostgreSQL,
> "SHAPE_ENCODING" in ESRI Shapefiles, etc). Overly complicated for
> programmatic access.
> Strings being set should use UTF8 encoding. Strings being read should
> assume
> UTF8 encoding. Not sure about the column names, layer names and such, but I
> would rather find the drivers that are not assuming utf8 and fix those than
> doing some extra complicated magic in the C# bindings. It simplifies logic
> greatly.
> If the underlying data store is using Windows-1252 encoding internally,
> that
> should be handled and abstracted out by the driver itself (by doing the
> conversions into utf8), not the bindings.
> My two cents,
> - Ragi
> http://osgeo-org.1560.n6.nabble.com/gdal-dev-GDAL-OGR-C-wrapper-and-UTF8-tp5044028p5044395.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130403/4d66c16b/attachment.html>
