[gdal-dev] Geopdf dependency on Poppler and Visual Studio 2012
Joaquim Luis jluis at ualg.pt
Thu Apr 25 07:40:33 PDT 2013
Jeff,
I built it from from source (from the git repo actually) and don't
remember to have had any particular problem. They provide a cmake
solution, which creates only a static lib but it linked fine with my
VS2012 GDAL build.
Joaquim
> Hi,
> I'm trying to build GDAL using Visual Studio 2012 and run into an
> issue with Geopdf format.
> This format depends on Poppler (or podofo) 3rd party component.
> Is there a VS 2012 compatible Poppler library for win32 and x64 bits ?
> I downloaded the Poppler library from
> http://vbkto.dyndns.org:1280/sdk/ but it appears
> to be a static .lib built using Visual Studio 2010. If it was a stub
> .lib (with run time .dll) I can
> consume it from Visual Studio 2012, but its unfortunately a static
> .lib (that VS 2012 can not link without errors).
> Thanks
> Jeff
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130425/c991b960/attachment.html>
