[gdal-dev] OGDI dead?
William Kyngesburye woklist at kyngchaos.com
Sun Aug 4 11:44:30 PDT 2013
Odd, it's working now.  Though I'm guessing that it will fail if it tries to load libdtusa.so to do a datum transform (or whatever it does with libdtusa.so).  Is this even possible from GDAL?
On Aug 4, 2013, at 12:23 AM, William Kyngesburye wrote:
> When doing some dependency updating for my GDAL I noticed that OGDI stopped working, and it looks like it's because of a change in PROJ 4.8 - not only was the projects.h removed from installation, but the nad_init call changed (ie binary incompatibility).
> There hasn't been a release since the 3.2 beta 2 in 2008, and neither has the cvs source on Sourceforge been updated.  There is a bug report there about this PROJ issue from over a year ago.
> Will this ever be fixed?  Is there a simple patch to fix it?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
