[gdal-dev] OGDI dead?
Sun Aug 4 21:26:30 PDT 2013
William,
Interesting point.  It would appear I'll need to do a few small fixes to
OGDI to keep it building, though I normally just work around the projects.h
one.  In fact, I'm only vaguely familiar with the existance and role of
libdtusa.so so perhaps that has been broken for a while too.
Best regards,
Frank
On Sun, Aug 4, 2013 at 11:44 AM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> Odd, it's working now.  Though I'm guessing that it will fail if it tries
> to load libdtusa.so to do a datum transform (or whatever it does with
> libdtusa.so).  Is this even possible from GDAL?
> On Aug 4, 2013, at 12:23 AM, William Kyngesburye wrote:
> > When doing some dependency updating for my GDAL I noticed that OGDI
> stopped working, and it looks like it's because of a change in PROJ 4.8 -
> not only was the projects.h removed from installation, but the nad_init
> call changed (ie binary incompatibility).
> > There hasn't been a release since the 3.2 beta 2 in 2008, and neither
> has the cvs source on Sourceforge been updated.  There is a bug report
> there about this PROJ issue from over a year ago.
> > Will this ever be fixed?  Is there a simple patch to fix it?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130804/226c0c44/attachment.html>
