[gdal-dev] problem with importing gml file to PostGIS with ogr2ogr
Piotr Pachół piotrpachol at gmail.com
Mon Aug 5 16:50:41 PDT 2013
Thanks for your explanations but I still can't import polygons which
contains many vertices.
I do some test with polygons which contains different quantities of
vertices and
on my computer and configuration I can import polygon which has 2046
pairs (x,y) of coordinates
but I can't import when it has 2047 pairs and more.
The length of hex string which is created in attribute
geometry(Geometry,2180)
can't be longer than 65534 chars.
Where eventually to change  some configurations variables of PostGIS or
Postgres or ogr2ogr ?
Do you have any other suggestion ?
Piotr
W dniu 2013-08-05 22:19, Even Rouault pisze:
> Selon Piotr Pachó <piotrpachol at gmail.com>:
>> Hello list,
>> I have problem with importing gml file (with polygons) to postgis using
>> standard ogr2ogr command which look like:
>> ogr2ogr -a_srs EPSG:2180 -f "PostgreSQL" PG:"host=localhost
>> user=postgres dbname=test password=postgres port=5432"
>> d:\test\BDOT10k\OT_ADJA_A.xml
>> I tried to import two GML files (with xsd schema necessary):
>> - OT_ADJA_A.xml -  is orginal valid xml file - after import to Postgis a
>> table is created but geometry column is empty,
>> - OT_ADJA_A_changed.xml - is changed and not valid xml file - but after
>> import to Postgis a table is created and some records have geometry, the
>> other not.
>> All files are accessible here:
> https://drive.google.com/folderview?id=0B54CPoAEcivYOTZhNDlpU3hkTlk&usp=sharing
>> So I have the following questions:
>> 1. In file OT_ADJA_A.xml  Why aplication not recognize <ot:geometria>
>> element which is "gml:PolygonType" type ? (there is definition in
>> OT_BDOT10k_BDOO.xsd file)
> Because the OGR GML driver has limited support to parse .xsd files. The .xsd
> should be just near the .xml file, and with the same basename. But even if it
> was the case, it is just not smart enough to realize that <ot:geometria> must be
> a "gml:PolygonType"
>> 2. In file OT_ADJA_A_changed.xml I replace <ot:geometria> with
>> <gml:Polygon>. Why in that case some of records are imported with
>> geometry and the other not ?
> I don't see that problem. In the sample you've provided, there are 6 features
> with geometries and the 6 are imported into PostGIS with their geometries
>> 3. Is there any constraints of Postgis or ogr2ogr in quantity of
>> vertices which can have a Polygon ?
> No, you're only limited by the size of virtual memory (and possibly a PostgreSQL
> limit on the size of records or fields)
>> I will appreciate any help.
>> Regards,
>> Piotr
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
