[gdal-dev] issue with gdal.Open() on new USGS GeoPDF
Even Rouault even.rouault at mines-paris.org
Thu Aug 15 08:30:16 PDT 2013
Le jeudi 15 août 2013 16:45:25, Reaves, Timothy a écrit :
> I sent the link off-list for the two files mentioned.
> Thanks for looking into it.
ok, the error comes indeed from Poppler itself at opening time. I've
implemented a workaround in http://trac.osgeo.org/gdal/ticket/5201 to avoid
the error to be propagated to the Python bindings.
I've compared the pdf with the "Couldn't find group for reference to set OFF"
error and the older ones that don't show that error
The newer ones miss the following PDF object :
     Item[0] : OC2
      Type = dictionary, Num = 640, Gen = 0
       Item[0] : OCGs
        Type = array
         Item[0]:
          Type = dictionary, Num = 46, Gen = 0
           Item[0] : Name = Orthoimage (string)
           Item[1] : Type = OCG (name)
         Item[1]:
          Type = dictionary, Num = 51, Gen = 0
           Item[0] : Name = Images (string)
       Item[1] : P = AllOn (name)
       Item[2] : Type = OCMD (name)
I'm not 100% sure that this is the reason for Poppler to emit the error, but
this could be a good track. I'm not sure if the problem is in the PDF file
themselves not being conform to the PDF spec, or in Poppler itself.
As far as the "unknown" name of the GEOGCS object in the WKT of the SRS, this
is not a problem at all. This is due to the GEOGCS having a custom definition
with a TOWGS84 node. You can ignore that safely.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
