[gdal-dev] Accessing ArcGIS Rest service troubles
Even Rouault even.rouault at mines-paris.org
Tue Aug 27 11:43:16 PDT 2013
Le mardi 27 août 2013 11:19:57, Pavel Iacovlev a écrit :
> Hello,
> I get a segmentation fault when I try to access data from an ArcGIS
> Rest service:
> OS: Ubuntu 12.04
> GDAL: GDAL 1.9.2, released 2012/10/08
> GDB:
> Starting program: /usr/bin/gdalinfo
> "http://geoportal.ancpi.ro/cachegis/rest/services/ImobileStereoPublic/MapSe
> rver?f=json&pretty=true" [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff73d4c50 in std::vector<std::string,
> std::allocator<std::string> >::~vector() () from /usr/lib/libgdal.so.1
I don't reproduce the crash with 1.9.2 on the older Ubuntu 10.04
> I tried on a different machine where I have a newer GDAL, here it's
> just a unsupported format error
> OS: Ubuntu 10.04
> GDAL: GDAL 1.10.0, released 2013/04/24
> ERROR 4: `/vsimem/http_1/file.dat' not recognised as a supported file
> format. ERROR 4: `/tmp/file.dat' not recognised as a supported file
> format. gdalinfo failed - unable to open
> 'http://geoportal.ancpi.ro/cachegis/rest/services/ImobileStereoPublic/MapSe
> rver?f=json&pretty=true'.
> Any ideas whats wrong ?
Nothing. It is just that this ressource is a ArcGIS raster map, and this is
not supported currently. Only vector JSON is supported through ogrinfo.
> Best Regards
> Iacovlev Pavel
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
