[gdal-dev] Default GeoTransform for MEM driver
Ivan Lucena lucena_ivan at hotmail.com
Mon Dec 9 09:08:19 PST 2013
The other problem with that documentation is the return code. CE_Failue means that the driver does not support it and/or that the dataset doesn't have it.
Date: Mon, 9 Dec 2013 10:55:34 -0600
To: jukka.rahkonen at mmmtike.fi
CC: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Default GeoTransform for MEM driver
Right. Thanks for checking into it.
I guess I was thrown by http://www.gdal.org/classGDALDataset.html#af9593cc241e7d140f5f3c4798a43a668
which gives the default as {0, 1, 0, 0, 0, +1}.
Is there a library wide convention on this? I can update the docs if so. (I assume its a simple pull and send a diff type setup.)
THK
On Sun, Dec 8, 2013 at 11:27 PM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi> wrote:
Tim Keitt <tkeitt <at> gmail.com> writes:
> I notice that the "MEM" driver returns {0, 1, 0, 0, 0, -1} by default. Is
this a bug or do some formats flip the vertical axis? If so, what is the
convention for detecting and handling "south up" formats in code?
I guess that anchor point is at the top left corner and therefore the north
coordinate is decreasing step by step when you walk downwards. Document
http://www.gdal.org/gdal_tutorial.html supports my thoughts.
-Jukka Rahkonen-
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.keittlab.org/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131209/37c5d97b/attachment.html>
