[gdal-dev] Default GeoTransform for MEM driver
Even Rouault even.rouault at mines-paris.org
Mon Dec 9 11:54:35 PST 2013
Le lundi 09 décembre 2013 18:08:19, Ivan Lucena a écrit :
> The other problem with that documentation is the return code. CE_Failue
> means that the driver does not support it and/or that the dataset doesn't
> have it.
The current behaviour of the MEM driver doesn't particularly shock me. It
seems OK to return CE_Failure if SetGeoTransform() hasn't been explicitely
called to define it. And as far as the default geotransform, it is a matter of
taste. [ 0, 1, 0, 0, 0, 1] would be indeed a bit more classical for a
ungeoreferenced image, but one can consider that if GetGeoTransform() returns
CE_Failure, the returned geotransform is to be ignored.
To answere Tim's initial question {0, 1, 0, 0, 0, -1} is a north-up image :
(0,0) is the coordinate of the upper left of the top left pixel, and y values
are decreasing with image rows.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
