[gdal-dev] Converting ecw to tif for Geoserver
Andrea Aime andrea.aime at geo-solutions.it
Sun Feb 10 11:51:00 PST 2013
On Sun, Feb 10, 2013 at 8:30 PM, Paul Meems <bontepaarden at gmail.com> wrote:
> I don't see anything about compression.
> Did I loose it along the way? Or is it expected to have such a large sized
> end result.
> Because it is now so large I think I'll get into trouble when I add it to
> Geoserver. I hoped to use the tiff directly and not use Geoserver's pyramid
> plug-in.
As said before, GeoServer cannot recognize the GDAL alpha mask, so even if
you manage to load it (it's a BigTIFF, it should
be possible to load it, we tested TIFFs up to 100GB) you'll lose
transparency anyways.
Cheers
Andrea
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130210/fe34e3b6/attachment.html>
