[gdal-dev] ogr2ogr convert e00 to shp
Andre Joost andre+joost at nurfuerspam.de
Fri Feb 15 11:33:23 PST 2013
I had this problem too if the file "file.shp already exists. GDAL does
not want to overwrite such a file, but create a directory instead.
So bet workflow is to delete the output file, if it exists, and then
carry on with ogr2ogr:
  if exist file.shp del file.shp
  ogr2ogr -f "ESRI Shaoefile" file.shp ...
HTH,
André Joost
Am 15.02.2013 18:46, schrieb Murat Beyhan:
> I was creating shp file using ogr2ogr as follows
> avcimport file.e00 coverage
> ogr2ogr -f "ESRI Shapefile" file.shp coverage
> This was worked well for old version of gdal
> I have installed gdal 1.9 then I have faced such a problem
> the ogr2ogr command create a directory and shp file located unter that
> directory.
> But old version of ogr2ogr was created files under the same directory where
> you work
> the old version of ogr2ogr creates file.shp file.shx file.dbf
> but new version create directory under working directory called file.shp
> instead of file.shp file
> and the shp files located under file.shp directory
> Please let me know what is differs this resuts.
> Regards
> Murat
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
