[gdal-dev] DBF handling
Uffe Kousgaard uffe at routeware.dk
Fri Jan 4 02:37:57 PST 2013
When DBF files has numeric fields with values > 2GB, processing fails
and all values come out as -2147483648.
My current work-around is manually changing the fields from Numeric to
Char (changing the header of the DBF), but it is really an ugly hack and
spaces for padding are wrong (numeric fields are right-aligned, while
char-fields are left-aligned internally).
It would be nice if at least int64 was used for integers in OGR, rather
than int32. Large integers are typically used as identifiers in
databases such as TomTom, OSM etc.
Has this been reported before?
Regards
Uffe Kousgaard
