[gdal-dev] libFileGDBAPI.so not found with compiling gdal 1.9.2 on openSUSE 12.2 x64.
Donovan Cameron sault.don at gmail.com
Fri Jan 25 10:05:43 PST 2013
Thanks for the suggestion Jan.
I tried to compile the 32-bit libgdal with the 32bit FileGDB_API but
still throws the same error...
Is it possible that the osc tool is looking inside it's build
environment at /tmp or /usr/tmp instead of my local user files at
/usr/lib64?
I might take this problem to the package maintainer for libgdal on
openSUSE 12.2 to see if they have attempted to compile with FileGDB
support.
On Fri, Jan 25, 2013 at 1:19 AM, Jan Heckman <jan.heckman at gmail.com> wrote:
> Hi,
> On windows, using visual studio (2008 and 2012), I could compile both 32
> bits and 64 bits, but only the 32 bits version actually worked.
> I haven't tried to figure out why the 64 bits version didn't work, 32 bits
> was good enough for me.
> Hope this is an option for you as well,
> Jan
> On Fri, Jan 25, 2013 at 5:23 AM, Donovan Cameron <sault.don at gmail.com>
> wrote:
>> Looks like over in the [qgis-user] list, someone is having similar
>> problems:
>> https://groups.google.com/d/msg/qgis_user_remote/B2J9sOsSLbo/BIpAHZ84bhgJ
>> On Thu, Jan 24, 2013 at 9:05 PM, Donovan Cameron <sault.don at gmail.com>
>> wrote:
>> > I can't seem to compile GDAL with FileGDB support on openSUSE.
>> > I'm compiling locally using the OBS tools (osc) and have checked-out
>> > the libgdal package from the Application:Geo project.
>> > Steps I've taken:
>> > 1) Download FileGDB_API_1_2-64.tar.gz
>> > 2) tar xzvf FileGDB_API_1_2-64.tar.gz -C /usr/lib64/
>> > 3) export LD_LIBRARY_PATH=/usr/lib64/FileGDB_API/lib
>> > cd /usr/lib64/FileGDB_API/samples
>> > make
>> > cd bin
>> > ./Querying #Works, so the API is fine.
>> > 4) su -
>> > $ vi /etc/ld.so.conf.d/fgdb.conf #Added a single entry:
>> > $ ldconfig #A grep of this with the -v flag shows it registered fine
>> > 5) #Some openSUSE specific stuff, b/c I'm building locally via the OBS
>> > $ zypper in osc
>> > cd /home/saultdon/Development/obs
>> > osc co Application:Geo libgdal
>> > cd Application:Geo/libgdal
>> > vi libgdal.spec #added "--with-fgdb=/usr/lib64/FileGDB_API" in
>> > %configure section
>> > #I also did a test build without that configure param. first and it
>> > compiled fine with working RPMs
>> > osc build openSUSE_12.2 x86_64 libgdal.spec --clean
>> > Resulting Error:
>> > [  209s] checking for libFileGDBAPI.so in in
>> > /usr/lib64/FileGDB_API/lib... configure: error: not found.
>> > [  209s] error: Bad exit status from /var/tmp/rpm-tmp.7SOa8g (%build)
>> > [  209s] RPM build errors:
>> > [  209s] Bad exit status from /var/tmp/rpm-tmp.7SOa8g (%build)
>> > The buildroot was: /var/tmp/build-root
>> > libFileGDBAPI.so file exists, ldconfig registered it, and the API test
>> > worked fine, the env. var. LD_LIBRARY_PATH is also set, but I don't
>> > even think that's necessary. I only had to set that to get the API
>> > test to work.
>> > I'm not sure where this is going wrong. If anyone has any input or
>> > needs more information, let me know.
>> > Thanks!
>> > Donovan
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
