[gdal-dev] MSSQLSpatial support for non-spatial tables
Jeremy Palmer JPalmer at linz.govt.nz
Wed Jul 17 02:17:32 PDT 2013
Hi gdal devs,
I've attached a patch to http://trac.osgeo.org/gdal/ticket/5155 to support listing, reading and writing of non-spatial tables within the MSSQLSpatial driver. The change also allows the user to set the MSSQLSPATIAL_LIST_ALL_TABLES=YES configuration option to be able to read and list non spatial tables.
Let me know if I need to do anything else to get the patch committed to trunk.
Cheers,
Jeremy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
