[gdal-dev] gdalwarp for affine transformation?
Agustin Lobo alobolistas at gmail.com
Thu Jun 27 01:26:22 PDT 2013
Is it possible to warp a raster using a 6 parameters transformation? I've found
that I can set gcp and the order of the polynomial in gdal_transform
and then use
gdalwarp to apply the polynomial, but is it possible to set the
transformation matrix?
Thanks
Agus
