[gdal-dev] Issues with FileGDB support
rburhum ragi at burhum.com
Mon Mar 18 13:45:52 PDT 2013
Hello quiztli,
I have it working on Windows and OSX. I believe EvenR did the port for
Linux.
If I had to do a wild guess, I would say that the dynamic library for the
esri implementation is not being found at run-time. Check your
LD_LIBRARY_PATH (Linux) / DYLD_LIBRARY_PATH (OSX) to make sure that the
required libraries will be found.
I would recommend stopping by the IRC #gdal channel on Freenode. If I am not
lurking, somebody else may be able to help you.
Best Regards,
- Ragi
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-Issues-with-FileGDB-support-tp5040537p5041216.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
