[gdal-dev] [SPAM?]: Re: Adding labels / specifying styles
Tyler Mitchell tyler.mitchell at actian.com
Thu May 2 09:06:10 PDT 2013
> However, I deal with a great number of files and I would like to accelerate the process. That is why I am asking for a script based solution. I can already import all my shapefiles with a Python script. I would like to indicate which column to use as label.
I see... perhaps you could look at creating QGIS project files directly.  Once you know the pattern you should be able to automate what you need, as the file is just XML and you can create one manually and inspect it.  I look forward to hearing what you figure out.
Tyler
